No Fuel or Spark, bad ECU? Please Help!
jeremylee_7
161
Aug 25, 2003
Yuma, Arizona
Hello, I have a 92 laser awd that will not start, I am getting no fuel or spark.
FYI I have eprom ecu, dsmlink v2.5, denso 660s, agp l2r and supporting mods
I have checked the CAS sensor and am getting fluctuating voltage at the ecu while I hand rotate the CAS. I checked the output for injector 1 and 2 from the ecu (pin 51 and 52) while the CAS is being hand rotated and the voltage stays constant at 9 volts (battery is a little drained when i checked which is why it is only 9v).
Does this sound like a fualty ecu, and what should the ecu be outputting for the injector pin wires?
Thanks in advance for the help.
Jeremy
