no spark or fuel
5spd94talon
Oct 23, 2007
Canal Winchester, Ohio
:confused:i cannot find anyone with the same problem as i have. sorry if this is a repeat but i really need answers. i will start off by saying the stock motor in my 96 gsx spun a rod bearing and i went ahead and bought a jdm motor. i bought it off ebay and every since i put it in i have not got spark or fuel. the fuel will get to the fuel rail but the injectors will not fire. the motor is a 7 bolt. i have changed the crank and cam sensor off of my old motor that used to start and the new one will not spark or the injectors will not fire. i have also tried switching ecus with my buddy. that did not work as well. if you would please help i need some answers. i am getting voltage to the sensors if that helps.:mad:
I assume you have checked all your fuses.. if not do so now main fuses as well.. what happened once with me is the plugs for the cam crank or a/c pump were the same or something like that.. they plugged in to the same plug so make sure u dont have the wrong plug plugged in
when you turn the key on does the boost gauge go to zero and does the check engine light come on for about 5 sec then go off!!! if not bad ecu i had the same symptoms after my engine build and thats what my problem was good luck!
