no first, second, or OD
WadexTSi
69
Dec 12, 2003
Detroit, Michigan
I was pulling away from a light on my way home form work yesterday and the the car would barely get going. Even at wot it wouldnt go anywhere until it inally got up to speed. It was obviously stuck in third gear and the OD light and power/ economy light werent showing on the dash. I pulled into a parking lot and found it would go into neutral, reverse, park and third, but thats it. I checked all the connections and the linkage to the shifter and there was notthing that stood out. Limped it home in third. Anyone have a clue?
That's called limp mode. Pull codes from the TCU and see what's going on.
Mike
thanks guys, this ones the daily driver and Im new to automatics, so your help is much appreciated.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
