No evap purge solenoid
chet1185
317
Feb 15, 2014
trevorton, Pennsylvania
Someone did a 6bolt swap and im trying to figure out all the vacuum lines. I don't see the evap solenoid or even a connector for it. The car is a 98 gst.
Also the egr valve just has a hose connecting one nipple to the other. The fpr isn't even done right. The nipple is just ran to the intake instead of from the intake to the solenoid then to the fpr.
Anyone Have a part number for the purge solenoid?
Just picked up a used evap solenoid. The connector on mine is round and this solenoid is square. The car didn't come with one so I didn't know what it looked like. Can I buy the pigtail for this solenoid and splice it on, or should I just try and find the right solenoid?
Why are they different? Dude said it was of a 2g.
Need help. If i can get a connector to splice on.
So, nobody knows anything about the evap purge solenoids and if i can splice a diff pigtail on. And where to buy 1
What if i get the pigtail from the earlier years? Will that work?
Here is my pigtail but I cannot find a 98 solenoid.
JNZTuning lists it in their online catalog for $35.01. Have you called an OEM parts vendor to see if these are still available?
I was trying find a used one.
I want this check engine light gone.
