1G No cooling fans when A/C button is engaged.
Mitsi1991
Oct 11, 2011
Henderson, Colorado
So Im having a bit of a head scratcher on my 91 eclipse? Its happened randomly? First my defroster switch stopped working and ive tried a few new known working switches and they still dont work. Ive checked the fuses they are all good. And of course the only way I can keep my motor cool is so click on the a/c and have the fan engage. How ever they no longer turn on when the heating fans are turned on and the ac is engaged? (Note: eclipse doesnt have A/C installed
Check out this post here: 1G Radiator Fan Cooling Issue
Read it through because I put diagrams and explanations in there that I don’t have time to repeat at the moment :cool: It should give you an idea of how the circuits work for the fans.
If you have zero fans with the AC switch on, I’d bet you have a relay issue. Check your fuses too, but that’s usually a no brainer. You need section 8 page 100 [Air Conditioner Circuit] of the FSM.
All fan control (both the radiator fan and condenser fan) passes over to a separate relay (the condenser fan hi-lo relay) anytime the AC is on. Does your radiator fan still work after the car is up to temp without the AC on? I bet it does. :D
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
