no boost & wierd nosie???
Bmxr152
579
May 27, 2006
Gardnerville, Nevada
Ok my i started my car after sitting for a while and and took off and had i halfway down and didnt really seem to be going like usual so i pinned it and didnt seem to go any faster. The revs went up so slow. And hitting a max PSI of like 3. I went home and let it sit then drove it again. i started it and pinned it down the street and it started to sound like a WRX like a double exhaust sound and at WOT it coulda hit 60 from zero like in 30 seconds. Whats going on?
While you're doing your boost leak test, check the shaft play on the turbo by trying to wiggle the compressor wheel. Grab it with your fingers and try to push it up and down, side to side, and in and out. While you're doing that, make sure it spins freely. Any play indicates that the turbo seals/bearings are failing. When my T25 went out, boost decreased from 12 to 10 to 7 to 0 over the course of a two days.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
