strange nosie after 4500 rpm ?
90 Talon AWD
148
Aug 27, 2008
jonesville, North Carolina
i had to replace the head and timing belt and after i got it all finished i was driving and after about 4500 rpm a strange roaring sound starts. It comes from the timing belt side and doesnt lose power or boost. Its just it makes me afraid to go that far past 45. If anybody has any ideas on what is going they will all be appreicated. Because i have tried everything that i kno to do
Thanks
uh well its kind of hard to describe its jus like a real loud roaring sound but it drives and sounds completely fine up until 4500
this exact thing happened to me, ill put money that that balance shaft is 360 out, the marks will line up but it will not be in sync with the other shaft and cause a vibration/noise around 4K i have to take that belt off and in the back of the block there is a plug that u stick a screw driver in as u line up the oil pump sprocket witch is connected to that balane shaft i will fell the screw driver "fall" in when its line up it is dramatic u will see when u dop it. Hope this helps im 95% sure this is ## issue
Check your timing tensioner. Take your timing cover off and run the car and rev it up to 4500 and watch your timing tensioner. I had the same problem but mine was around 3k and stopped at like 3500 but after i rebuilt my head I ran it with the timing cover off in the garage so i could let the cams break in and I noticed it was bouncing around at 3k-3500. New timing tensioner fixed my problem. Hope this can help
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
  • For sale 4G63 MHI 20G Turbo
    MHI 20G Turbo $500 + shipping & paypal fees* setup for external waste gate * just serviced by...
  • For sale 2g 2G Manual Shifter Cables
    2G Manual Shifter Cables $90 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G Driver Side Drip Molding ( no peel or chrome showing )
    2G Driver Side Drip Molding $95 + shipping & paypal fees* no peel or chrome showingYou must...
