RayBan GST
- 665
- 4
- Oct 21, 2007
DUBAI UAE,
Asia
i heard a lot about these plugs BKR6 e-11 and i decided to try them , i did not have a gap tool so i just gaped it down as much as possible i dont know how much but its very tight almost no clearance. installed them and fired it up ,it started normaly , boosted the car up to 16 PSI on the t25 with no problem at all , car felt way much stronger/faster on these plugs. 3rd gear and 4th gear i noticed big big difference and also i was holding boost much longer. usually t25 on 4th gear wont hold and will die back to 10 psi but on these plugs redline was at 13 psi.
i used to have BPR6es before but after trying the BKR never again.
i know you will tell me the BPR6es are recommended but try the BKR first and then judge yourself.
zers.
