bkr6es-11 spark plugs
Time4the16G
33
Jul 18, 2009
Rialto, California
Is there a difference between BPR6ES and the BKR6ES? I've read a few post on dsmtuners but none of them really have a solid answer. I order my plugs from Sparkplugs.com and they said "BKR6ES-11" were the correct spark plugs BUT i just removed my old ones which are "BPR6ES" and there is a major size difference. "BPR6ES" is 13/16 while the BKR6ES-11 are 5/8. They BOTH fit in the engine, whoever will this change my performance?? Should I send them back??
Thanks for the help :hellyeah:
Our system uses the "6ES" plugs since we're dealing with high compressions due to turbo usage why we do the .028 gap setting.
"ES-11'S" uses a .044 gap for NT motors.
You shove in the "11" plugs in a turbo motor and good luck keeping the motor running for the higher compression will literally blow out the flame on the plug.
