next mod help
coryf1233
246
Nov 6, 2007
hanover, Pennsylvania
:talon:I have looked at the upgrade paths on here and a few other sites..but im wondering what peoples opinions are, on what my next mod should be( best bang for my buck kinda deal)
mods are as follows: 3 inch turbo back exhaust, palm m130 pocket logger, egt gauge,boost gauge, eibach sportline springs, k&n filter.
any help would be great!
many are just going to tell you to follow the upgrading paths on here. Since I'm bored I will entertain this thread until it gets moved or deleted.
How much money do you have to blow? What kind of car are you trying to make this and what are your goals?
im not by any means trying to make a track car, i want a nice, quick daily driver..My money situation is kinda tight for right now, paying for schooling and other things, but i want a good mod(s) for right now..If you have time maybe throw in some mods i should do in the future,, i realize this post is probably covered many times..i appreciate all who are willing to not tell me to search and actually give me some positive feedback
For cheap mods at this point according to your profile:
Port manifold/turbo/02housing
rewire fuel pump
mbc set to 16-17psi or whatever your idc% deems safe.(<90%)
Dont up the boost without at least rewiring your fuel pump
RRE Instructions
If it's a 1g (like your profile shows), you should consider doing a boost leak test, compression test, change your fuel filter, plugs, wires, etc. Then maybe a boost controler or fuel pump rewire.
ive already done alot of the basic maintenace stuff, but the compression test, boost leak test etc. I have but, not installed, a 2g manifold and o2 housing.
you can make this thread more exciting and post pics, since I may see you around this year. Hanover isnt that far...
I agree with the mbc, try and evo 8 fuel pump ($30 on evom), rewire...im assuming you have the 14b on there now? Heck you can even pick up cheap evo injectors, but then your looking at tuning it with a piggyback, wideband ,etc. You can pick up cheap piping and even a fmic if your feeling greedy.
