newbie
new2boost
Mar 28, 2009
schenectady, New York
hi i recently purchased a 1992 eagle talon dl with 230,000 (still runs strong) i obviously need more power what do you guys recommend? rebuild and turbo ? or how difficult is a gst swap? and as far as parts like camber kit and springs are they the same as a same year eclipse?:hmm::hmm:
If the motor truly has 230,000 thousand on it then turboing it is something that i would not consider at the time. If you want to go the turbo route then the first thing i would do is go back to the basics and rebuild the motor with forged internals and check the transmission out and make sure that it can handle turbo. I believe that the 1992 to 1994 eclipses and talons are very similier. i know that the 2g talons are the same body and suspension but the motor and trans are different in the non turbo and turbo versions.
With that mileage, I'd be spending a lot of time and $$$ in making sure that all the mechanicals are in goo working order and all the maintenance is done...before even thinking about more power.
Unless you're just building a race car. In that case... yank the motor, go turbo and drive like you stole it until the wheels drop off or the <insert part of your choice here> breaks. :)
Just an idea but do all the maintenance and make it your DD.
You can probably find a 1g turbo'd DSM for cheaper than you can bring yours to life and then turbo it.
I see them all the time here in Oklahoma on craigslist and such for less than $1000 in pretty good shape
Kolby
