Newbie help
winkdogydog101
123
May 6, 2010
Tucson, Arizona
LOL well you bastards i finally became a proven member like 3-5 days ago but i had questions that i couldnt find when i searched and felt they may be a bit noobie for the other forums.
my questions are
what is the difference in the holsets hx35 and hy35 other then how the downpipe fits on
with 272 cams intake and exhaust what are good springs i can use to up the redline. And with the cams how far will the powerband follow and still be efficent. I wanted to get a 8000-9000 redline.
Do they make coilovers with dampering for the 1gs that people have used for down hill runs that they can recomend because im having a very hard time finding ones that have a good rep.
whats the difference between the 3 bold lsd rear and 4 bolt lsd rear?
is the 3000gt brakes alot better over the stock ones since there 2piston? braking in this car blows.
thanks guys
Smaller turbine housing. HY35 = 9 CM ^ 2 and HX35 = 12 CM ^ 2
A set of BCs will do just fine. On the above turbos, it will hold it all the way through on the HX-35, probably on the HY35 as well since either one will require a housing change to be used on our cars.
Yes, insert random D2, KSport or Megan argument here.
A bolt. Also the strength of the case.
Two tea leafs on paper clips are stronger than our stock brakes. The VR4s are a much needed improvement.
Need at least 17s with a similar offset to Evo rims. You will need brackets that you can find at a supporting vendor here.
Use 90-93 calipers and 94-99 rotors (all from a 3KGT VR4 of course).
dude holy shit they are 4 pistion? damn i really want these now! and all ill need is front rotors
how much is the backet i cant find it the bolt patterns the same?
yea i think im gunna stick with the regular brakes i found a search that says you have to do custom fabing and its not worth the gains
what about redline and ### are good springs to get
