Newb DSMlink
Jooltz
3
Aug 26, 2011
Floresville, Texas
Hello, I just tried my first pull with ECMlink. Can someone give me a little insight on my knock problem?
Told you i was new. I will try putting up an actual log.
1. Fill out your vehicle profile. Without it, we have no idea what we are looking at.
2. According to the log, you don't have a wideband, MAP sensor, or anything else being logged. (See #1 above).
3. Make sure everything is correct mechanically (base timing, BISS, BLT, etc), and all of the initial ECMLink setup is covered. (TPS adjustment, input assignments, etc). This page has links to a lot of info and guides.
4. Post a log that shows warmed up idle and light cruising. You gotta walk before you run. :)
You need a wide band.
Also, Log LFT Mid, LFT low and LFT High., You have to bring all LFT to 0 (as more as possible).
You shouldn't do that much Knock, You might damage your head gasket.
As soon as you see 3 or no more then 5 of knock, You should let it go, If you keep going, then be prepared to do a head gasket change sooner then you think.
Just purchased a AEM wideband and will be installing this upcoming weekend. Until than I will stay off the gas.
