baks2
- 0
- Dec 13, 2011
roanoke,
Virginia
I just brought a 1997 rs only problem is that it drives but after a few minutes or so it will stall after i stop and try to take off in first and won't start for a couple minutes later also i think it idles funny it starts at 1k then goes to 1.5k and back to 1k and the alternator belt squeals when it starts but not while it is running
here the things i plan on replacing on soon 1.crank and cam sensor 2. clean throttle body or replace it 3.check vacuum lines 4.replace alternator and belt
now is there anything else i should do while I'm in there i also would like to clean up my engine bay area any suggestion
s
s
umm i wouldnt do that, yes it does work but wen u hook it back up u can fry your CPU or othere senors and computers in the car from the voltage spike when hooking it back up...to test the alternator get a volt meter hook one end to the battery negative and hook the other to the power wire going to the alternator (the big fat red wire bolted to the alternator) and it should read about 14.7 volts wen running and 12.6 when car is off
