New Pics of my Roll Cage
Originally posted by 95GSXracer
I have a 50 trim, and can upgrade to a 60-1 for just about nothing. The only thing that concerns me is using the 60-1 with the straight TDO6 turbine wheel in a 7cm. Not sure it can get all of the air out that a 60-1 can put in. This talk of running faster on 50 trims also has me listening. Now my question is this. There are poeple running the 60-1 in the form of a FP red that dont seem to have this much trouble with lag. I have to assume the stage 5 wheel is going to have a much more profound effect on lag than the 60-1 wheel does. But I'll have to look at the 50 trim and 60-1 maps again to see the difference in wheel rpm to get the same boost...
Kevin,
As you pointed out, we are talking about all out Garret turbos. Oddly enough, it seems that 60-1 wheels stuck in machined Mitsu housings "seem" to perform better (if that is what Frank 5 and Red are using). There is probably more to it than just the wheel, so you might be in a better shape than us (using your hybrid turbo).
Leon
RR
SBR claims full spool around 4k rpms with their mitsu 60-1 hybrid. that doesnt sound bad, what kind of rpm were you hitting full boost at, GRNDSM? high 4k to low 5k? i would appreciate anyone else oppinion who has had experience with the SBR 60-1, i am planning on running this turbo and it WILL be street driven.
-Greg
Personally I would either use a TDO6H wheel or clip the TDO6 slightly. I think you will be restricting flow at high boost. Of course you could always get some sort of mechanical pressure gauge, tap the exh manifold collector, and actually measure backpressure to find out. With all the turbo setups people go through it suprises me that more don't do that.
Originally posted by ECLIPSE4x4
hahahahahaha... from look at my roll cage, to another turbo debate...hahahaha
"...Do one thing and do it well..."
All this talk about the 60-1 being laggy had be a little worried, then I remembered my Mustang worthy shot of liquid power adder, and lag doesn't seem to worry me as much. :D
On topic, the cage looks awesome. What kind of money did you have doing this yourself? Mild steel or chrome moly?
On a turbo note. I ran a 60 trim, and a stage V wheel in a .63 housing for 3 years.... Trying to get more out of it... Useless.... However, going from 93 mph in the 1/8 to 126-129 on the big end... priceless.
Regards
Mike Huml
Regards
Mike Huml
It's Mild, because I don't have a TIG :( I had about $300-$350 in materials (the hoop, strut kit, fasteners, hardware and paint) and probably 20 hours working time.
    • george bromwell
    • pma1123
    • Sdcryan1
