New Owner?
PHA-Q
Feb 11, 2004
Orange Park, Florida
I just got a 95 GST and I noticed that there is a oil leak by the oil filter. Not from the oil filter. But the housing beside the filter. It is the housing that the oil line going to the turbo. But I isn't leaking bad enough that it leaves a oil spot on the driveway so if you know what I am talking a bout any info will be great.
Also How do I adjust the clutch pedal I have to put it to the floor to get in gear.
I am a former Domestic Owner and Know Noting about GST's
It is the oil filter housing that is leaking. Mine leaves a spot here and there, nothing big to worry about. If you have to put in a quart a week, thats when you want to look into it.
To adjust the pedal, you loosen the nut that is on a threaded rod that comes out of the firewall. It goes to the clutch pedal, and by the sound of it you need to bring the threads to the firewall side of the rod. You should be able to adjust it with your fingers once the nut is loose, if not, just get some pliers and grip it at the flat part (you'll see once you get down there).
Proceed with some caution:
http://vfaq.com/mods/oilcool.html
It sounds like you have an after-market turbo oil line, possibly this one:
http://www.roadraceengineering.com/instructions/oillineinstall.htm
There is some controversy about how good an idea this is.
The clutch is probably about used up, but try your luck:
http://www.roadraceengineering.com/clutchandflywheeltech.htm
You're still a domestic owner. DSMs hail from Illinois, the motor and gearbox came from Japan. The Feds classify DSMs as domestics, 70%/30%.
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
