New owner of a 96 GSX
Im searching for an engine harness. The car is a 1996 GSX and I have a 6 bolt 4g63 engine that will be going in it. So, I would need an engine harness from a 95-96 and the CAS adapter from 6 Bolt Motor Install Into a 2G Eclipse
Check your local boards for part outs. Other than that your best bet will be the classifieds once you get enough quality posts.
You could also try going to a pick-a-part (U-pull or whatever your area calls them) and see if there is still a intact harness, at the local yard here we typically have a few. If there was a turbo 2ga in the yard I'd pull one for you, but no luck.
http://www.dsmtuners.com/forums/southeast-region-dsm/ Here is the Southeast Region's sub-forum. I don't know what city would be closest to you.
