New o2 Sensor
gophishy10
350
7
Apr 17, 2012
Boston, Massachusetts
My o2 sensor is shot and instead of getting a $80 new oem sensor, I want to go with a wideband since I will be doing a 16g upgrade soon. My question is if I already ordered a 3 pod gauge pillar with gauges (including a afr gauge) can I just get a wideband sensor? Or do I need to get the whole kit? Is there other parts in the kit I will need besides the actual sensor?
A wideband is a complete AFR measuring tool which is basically a gauge with its own O2 sensor. It can't be connected to a narrowband gauge (likely the AFR gauge you ordered) which is meant to read the factory O2 sensor. A wideband also can't be used in the front O2 location without running "narrowband simulation". This can be done through either a tuning device or by wiring the wideband into the front O2 signal input. But this is only if the wideband has a logging/narrowband output so research thoroughly before buying.
But for now I would replace it with a factory O2. I suggest oxygensensors.com for great prices on OEM sensors. Id also advise you to search the differences between a wideband and narrowband gauge.
Well won't I need a wideband once I do the 16g upgrade (with 255 fuel pump, new injectors, fmic) to properly tune it? I have SAFC just not installed since there's no point right now.
A wideband is a complete AFR measuring tool which is basically a gauge with its own O2 sensor. It can't be connected to a narrowband gauge (likely the AFR gauge you ordered) which is meant to read the factory O2 sensor. A wideband also can't be used in the front O2 location without running "narrowband simulation". This is usually done through a tuning device such as DSMLink.
So replace it with a factory O2. I suggest oxygensensors.com for great prices on OEM sensors. Id also advise you to search the differences between a wideband and narrowband gauge.
There are some widebands on the market that have a narrowband output from the controller that will allow you to run it to the ecu.
Like the Innovate MTX-L :) I love mine, I ran the narrowband simulation on it for a while and it works great. An AFR gauge that comes in a kit is more than likely going to be a narrowband, which is pretty much useless besides telling you your o2 sensor still works. If you do use the SAFC please make sure you have a good data logger to go with it, I've seen too many engine failures from bad SAFC adjustment :banghead:
True, totally spaced on that. Most quality widebands will have a 0-1v output wire that can be hooked to the Front O2 ECU pin to simulate the narrowband sensor.
Yes, you will need a wideband for tuning. But it's not required that you replace the front O2 with the wideband sensor, it's just less work since there's no need to weld in a new bung.
Thanks for all the input. I think I'll go with the MTXL Innovative Wideband from Extreme PSI. Seems like a good value. Spoolin, I would get it professionally tuned. I wouldn't take a chance of messing something up by doing it myself.
One other question...would the datalogger that comes with that wideband be sufficient for tuning later on? Or would I need anything else?
