New motor looking for help with last few things
str95tsi
251
31
Jun 19, 2014
Eugene/springfield, Oregon
First little things like spark plugs...
Iridium?
Do they make them for 2gs?
whats so great about them?
weather to run fuel injector clinic 1650 cc injectors compatible with all fuels.
or fuel injector clinic 2150 cc injectors?
Not compatible with all fuels.
I want to run 93 pump and E85-E95 possible to also finde race gas if i wanted it.
Coil on plugs...worth the $$$???
If so what brand?
Will it help make more power?
now that John Shepherd stop doing Dsm's do you recommend tre or Jacksons transmissions???
And i always felt 1st gear was to short so I'll probably go evo 3 1st gear and input shaft... 5th always seemed to short as well...any solution???
Think mountain passes and street car.
3k-7500 rpm power band.
whether to do with Magnus intake manifold or JM Fabrication?
Im running an FP Green for now.
Magnus, Aromotive, or F.I.C. fuel rail?
Is any better than the other in any way?
Coilovers? Best of the best?
Whats the best break upgrade for our 2g cars?
Evo brembo?
If so whats needed?
How do i go about running a fuel cell like the steath A1000 Aromotive with a walbro 450lph in stock tank?
Or would i be better off running a line from the stock tank to the fuel cell return and just run the A1000 pump?
What throttle body would you recommend useing?
5.0 mustang, s90 70mm or 74mm?
My subframe bushings are going out so solid polyurethane or rubber?
Stock moter mount bushings rubber or polyurethane?
Is the rear Magnus subframe as good as they say?as in worth $2400 ow?
Where do i find a full carbon fiber dash NOT a cover?
Where do i find i full fiberglass dash NOT a cover?
And more???????to come
Any one know what i should run as far as MAF?
I vent my B.O.V. to the atmosphere...
So gm MAF?
Someone i know sed run a pro MAF.
What's the differents?
Also what is all needed?
Gm MAF sencer, MAF translator, and?
Ok so i would run speed density but i drive this car everywhere as in high and low elevations.
So SD would mess with my tune.
I live at sea level and drive to 5,000 feet above sea level all the time.
Also my tuners say to run pro-maf 80.
but i plan on running a blow off valve that vents to the atmosphere.
So anyone know if i can do that with this?
http://www.promracing.com/pro-m-80.html
I was going to run it but idk if i can due to the b.o.v. venting to the atmosphere.
And if i cant use it what should i use thats a pro-maf?
How big can you port the stock intake manifold for throttle body on a 2g?
I'm thinking of getting an S90 74mm throttle body and I wanted to see if you guys and gals could shed some light on weather the S90 70mm or 74mm is better.
I plan on getting an intake from MAGNUS or JM fab but ive been a little low on funds so...
I thought I'd just put a 74mm on the stock manifold untill then.
But I thought you guys could give some input on port work and 70mm or 74mm.
Also what gaskets hold up the best for S90?
Thanks a ton
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
