94awdcoupe
- 1,416
- 215
- Nov 6, 2004
tampa,
Florida
In my quest to find a FUN turbo to run on a 2.3 powered evo 1, I found a turbo I have never heard of before. If you have been around the dsm thing for a while it doesn't take long to realize mitsubishi turbos kickarse comparred to garrett or turbonetics stuff. I think the best example of this is the 20g vs 50trim turbos. I have driven handfuls of both and would choose a 20g in a heartbeat. I have also had very good success with a 25g, which I think was actually more fun than the 35r that I am currently running on my yellow car. In my build-up of my evo1 I was looking for a turbo that was inbetween the 20g and 25g turbos without having to go garrett. Here is a comparrison of what wheels flow.
evo16 600cfm
20g 650 cfm
50trim 700cfm
24v 800cfm
25g 850cfm
60-1 900cfm
I have a 24v turbo here and have been comparring it to the 60-1 wheel. .It is the same 7 splitter design. It has all the same great mistubishi quality that makes mitsubishi wheels shine. The wheel is 1mm smaller inducer, but 2mm larger exducer. Blade thinckness is same mitsu quality .025 thick vs .034(60-1). Same small hub like evo16. blade dept is about 3mm deeper than 60-1 at the middle of the blade. 18mm vs 15mm (very opproximate). This wheel should be very lite comparred to 50trim or 60trim, Should perform very nicely. The turbo comes with a very sheek 4inch inlet ported compressor cover. very near the size of s cover. Good stuff. Oh did I mention you can get these turbos for half of what a new green or red would cost you. Turbo is 625 shipped from japan . It comes with useless 12 or 16cm ex side so you will have to source a 7 or 8cm or bullseye housing.
Cheers,
lancerman
evo16 600cfm
20g 650 cfm
50trim 700cfm
24v 800cfm
25g 850cfm
60-1 900cfm
Cheers,
lancerman
