New Log,,Weird Stuff,,Please Look...
BOBS90TURBO
581
5
Sep 18, 2002
Tulsa, Oklahoma
Ok I just did a log tonight after working all day to get my fuel trims good and what happened was not normal for my car, first off I normally boost around 17psi but had turned up my boost a tad and ended up at 22psi and around 5500RPM I started blowing a little white smoke out the exhaust(Is this just fuel) It never smoked driving normal or ay 17psi. And the CRAZY thing I noticed about this log was my timing was being pulled and I had zero knock, the car felt like it was cutting back a tad around 5000+ rpm and then I looked at the RPM's on my log and noticed this(RPM going up and down).
RPM KNCK 02 TIMING TPS INJP
3062 0 0.76v 24* 99.6% 7.67ms
3218 0 0.76v 23* 99.6% 8.19ms
3375 0 0.76v 24* 99.6% 8.44ms
3468 0 0.76v 24* 99.6% 8.95ms
3656 0 0.78v 23* 99.6% 9.98ms
3812 0 0.78v 22* 99.6% 10.75ms
4031 0 0.78v 22* 99.6% 11.51ms
4250 0 0.80v 21* 99.6% 12.54ms
4437 1 0.80v 20* 99.6% 14.33ms
4593 2 0.78v 18* 99.6% 15.87ms
4843 1 0.78v 17* 99.6% 17.66ms
5000 1 0.78v 16* 99.6% 18.68ms
5218 0 0.78v 16* 99.6% 18.68ms
I let off at 5300rpm because I saw the white exhaust smoke, this was 3rd gear.
I then turned the boost down to 16psi and added 3% fuel accross the Hi and was still pulling Timing,,,WHY???? :confused: :cry: :(
3218 0 0.83v 22* 99.6% 8.95ms
3375 0 0.83v 22* 99.6% 9.47ms
3468 0 0.85v 22* 99.6% 9.72ms
3656 0 0.85v 22* 99.6% 10.75ms
3906 0 0.85v 21* 99.6% 11.51ms
4062 0 0.85v 20* 99.6% 12.54ms
4218 0 0.85v 19* 99.6% 13.56ms
4468 0 0.85v 19* 99.6% 14.07ms
4593 0 0.85v 19* 99.6% 14.50ms
4718 0 0.87v 19* 99.6% 14.59ms
4843 0 0.87v 17* 99.6% 15.35ms
5156 0 0.87v 17* 99.6% 15.35ms
Any ideas why I am pulling Timeing,
Something's not right. You're timing should drop down as boost hit's and then climb back up till redline.
Have you checked your base Timing?
PS white smoke isn't Fuel...
I had checked my base time a month ago and it was perfect, I since advanced it a little, I was told I should do that because I had zero knock. Could this be the problem??? I will retard it a little and go make another log.
About the white smoke, like I said it was doing it at 22psi but since I lowered psi to 17psi and now it is not doing it anymore(for now at least). :(
Ok, I fixed the timing advancing problem, I had to retard the timing a little and it is advancing perfect now. But now I have a new problem, I hit fuel cut for the first time ever, and the sucky thing is I just got my fuel trims almost perfect, so I either have to run bad trims(to lean) or run good trims and be to rich and hit fuel cut. :cry:
