LV-DSM
Supporting VIP
- 121
- 2
- Oct 6, 2002
Las Vegas,
Nevada
Here's the situation. 1g. FWD. New engine, old trans (worked fine before), new clutch disk, plate, TOB, and flywheel. Bled the clutch, feels great. Installed shifter cables and cannot get into any other gear but 1st and neutral. When in nuetral, shifter could not wiggle left or right, but you could tell that 1st had disengaged. I removed the cables from the select lever and shift lever at the tranny. Shift lever movement is fine, but select lever will only enter 2 of 3 possible possitions. Forward (towards radiator) and middle. It will not move backwards allowing the shift lever to rise.
What could have happened? Should I have been in a specific gear before installing the trans? Is it possible that the clutch fork slipped off of the pivot ball or is it something else? I really don't want to remove the tranny again to troubleshoot.... Sucks to do by yourself.
Need some advice please. TIA
