AL92
- 933
- 4
- Dec 12, 2003
regina,
SK, Canada
I did a new engine but apparently its fubar now at 4000 miles. So doing another one or rebuilding it .
Anyway I had numerous oil leaks on the new motor. I used new gaskets of course but think it was a topline kit or something not oem for most of them. I even did my oil pan three times ,a new oil pan not warped .First with gasket that came in the kit. Then with permatex gray,then with mits rtv. It leaks still. Also many places are leaking by oil filter housing,etc.
I put most of the gaskets on dry. Someone said to spray them with gasket sealer or something. I torqued things to spec but possible some bolts came out I used blue loctitie on most every bolt. Should I use red or put lockwashers under most bolts?My engine did seem to have a lot of buzz and loosen up bolts. It was a 2.4 with no balance shafts and was not balanced but had a fluidampr and had poly inserts front and back.
I am going to balance things this time around. Debating puttting balance shafts back in there but really don't trust the things.
So you smart mechanics is there something to spray the gaskets with so they quit leaking all the time. I think mostly the problem is the paper gaskets. I am so sick of having oil all over my driveway from this car. Why do dsms use so many darn gaskets. I swear the gaskets are like 10 times what is in my v8 chevies.
More gaskets the more places to leak.And leaks might have killed my engine as always had to add a quart every two fill ups.and it didn't burn any.All leaked and seeped out of hte motor!
