iamtall77
- 185
- 1
- Oct 9, 2002
Las Vegas,
Nevada
Okay i hate that my car leaks oil, but some of it can't be helped, it's a DSM. However, leaking a quart of oil every 500 miles or so is unacceptable. It seems to be leaking form the oil filter housing area. Yes I did the BS removal, so that may have started it. It seems to leak oil from the BS tension pulley hole. What's the fix? Should I put a dab of silicone under the head of the bolt to seal it to the front case better? What about the oil filter housing? I've used just a gasket and then tried to seal the gasket with silicone. Then I tried to seal it with just silicone. No good. Should I try to seal it again with just a gasket? Should I over torque the bolts or try anything else? (torque spec is 16lbs i think) This really sucks and it even gets on my timing belt. I will of course get a new belt when i can control the leaking better. Anyone have a "magic" fix? Hell, I'll settle for a non-magic fix. Help me out please.
