mikevar94
- 115
- 1
- Apr 25, 2013
Waterbury,
Connecticut
Alight guys please I need help. I'm so frustrated at this point. Almost makes me wanna put a for sale sign on it. I just put in a competition stage 2 clutch. It was done by a local shop. They put it in and when I got it back it was slipping like crazy. I brought it back. Now they claimed they have fixed it. I just picked it up for the second time and now it's EXTREMELY hard to shift. Especially into 1st and reverse. I feel like Im breaking it. After some driving I stopped and looked up what this could be and found it its clutch drag. I did the test btw where you put it in gear and revved and guess what...she starts moving. I figure oh maybe the pedal needs to be adjusted so I look underneath at the rod adjuster and notice that its maxed out all the way to end of the rod. You can barely even see a thread. I tried tightening it the problem got worse so my guess is that the mechanic that worked on my car went thru this also and just maxed it out because it shifts at that point but barely. Can anyone tell me what I need to do?! It's a Saturday night and they're closed tomorrow and I can't keep getting rides to work like this. When I was driving it for the 20mins after I picked it up today, the clutch felt great (besides the shifting). Catches nicely, no slipping, pedal felt nice. It had more resistance but not too much more. This leads me to believe that it's not a clutch issue and more of an adjustment issue. Maybe needs to be bled more? Anything could help!
Btw, in the how to properly adjust you clutch pedal video from jack transmission, he talks about adjusting the button right in front of the pedal that is pressed in when its not depressed. Think that needs adjusting?
Also something's I may have forgot...when I was messing around with the pedal adjustment the pedal just sank to the floor and stayed there when I just applied a little bit of pressure. That kinda makes me think it needs to be bled. Also my shifter kinda feels loose. Like there's about 1cm of play when moving side to side in neutral. Kinda hard to explain but it didn't do that with the oem clutch.
