New brake job yet e-brake stuck (cold in de)...
AWDTalonDE
126
Nov 25, 2004
Columbia, Maryland
My dad and I inspected my rear brakes ( already did everything for front) and I needed new calipers rotors pads so we did them. However the e-brake has been acting up and sticking.
When it is up for a period of time and I go to drive and pull it down it wont roll in neutral. If I go to lift the e-brake lever up it will be very loose and feels like it is already on and stuck. My dad noticed that the driver's side rear brake is missing a clip that connects the e-brake cable to the caliper.
I was wondering what I should go about to fixing/diagnosing this problem? Should I check the rear/ t-case/ tranny? Should I just try to find the clip he is talking about? Perhaps it is just frozen because of the recent cold weather?
Any help would be appreciated, BTW I drive a 90 TSI AWD, thanks.
Salt things there, do they? Get under the car and find out what all's seized up. Better to replace what you can if you see a lot of corrosion. And replace missing clips and other hardware.
I'm having the same problem as you actually. And it's even the same brake (drivers side rear) I notice if i take the wheel off i can manually move the ebrake line back to where it should be. But if i just use the lever inside the cabin i can engage it but not disengage. I originally thought it was the spring on the caliper because it was worn and didn't have nearly the strength it should have to push the line back. Now I've installed a new caliper and the problem still remains. I'm figuring that replacing the ebrake line for that caliper will fix the problem but i don't want to jump the gun and buy it before i get under there to look. Hopefully it's just getting snagged on something. Let me know what you find out when you get in there.
Hi bringing this back up as my problem still exsists...since then I've checked everything out and it apperas the e-brake is being frozen...maybe...I'm thinking of replacing both e-brake cables. Anyone else have any suggestions?
Thats what I would suggest...same thing happended to me on my 1g....I was going to replace the cables....then next thing I knew I was knee deep in a 6 bolt swap into a 2g :sneaky:
