New Afordable Wideband Oxygen sensor tuning everything you need for $350
AWDlaserRS
411
Nov 30, 2002
I saw the guys on 2 guys garage using it today on a Riviera (think it was a riviera?) anyways it everything you need minus a computer to tune your car with a wideband o2 sensor, comes with the unit a wideband o2 sensor, all cables, all software and even a bung to weld to your downpipe for the sensor (which means you dont have to mess with your existing 02 sensor) All this for $350 thats like the price of an AFC.
Heres the link: http://www.innovatemotorsports.com/lm1.php
Yup. I have one, and it is very nice.
You probably want to pick up the RPM sensing stuff, so that you can datalog A/F ratio vs. engine speed. That will bring the price up an additional 100 bucks, but it is still worth it.
I think Im gonna buy one of these things.
kpt4321 can you just leave the wideband 02 sensor in all the time or will it not last very long and you only use it when tuning?
Also how easy is it to tune with? It looked pretty easy on the show I saw today.
You can leave the sensor in all the time IF the wideband is powered up whenever the car is on and you do not run race gas.
Leaded race gas will kill the sensor.
Running the car without the sensor powered up will kill the sensor, because it needs to be heated.
I am buying this with the Exhuast pipe clip, and it should be here this week.
My question is, can it log and save stuff, then take it in to your PC then see what the car did? Or do you need a laptop in the car with you.
I plan to only run it when I am going to tune, then unclip it when I am not using it.
It records information that you can later download. Would be kind of a waste of money if all you could do was monitor what was going on in real time and not play it back. I believe it stores about 45 minutes worth of logged info.
Mine should be here Teusday w/ the RPM input and analog gauge as well. Came out to about the same price as the TechEdge unit, PLUS it can store info and it has compensations for altitude, sensor deterioration, etc. I can't wait for it to show up!
Chris
    • george bromwell
    • pma1123
    • Sdcryan1
