420A needing suggestions cams 420A
midfb6
44
6
Jun 25, 2024
COHUTTA, Georgia
Im currently turboing my 420a motor and have evrything ready to go in sept for cams, the crower stage 2 cams are a pain to find and have called around the only option is to send my oem cams to crower and they said they might be able to meet the specs of the stage 1 cams. Will the stage 1 specs work fine with turbo 420a , or if anyone has some stage 2 crower cams for sell please let me know.
Adding a turbo does not require a larger camshaft. The only instance you would "need" to change cams is if you had large cams with significant overlap.
okay that sounds good to me , i did already buy brian cower valve springs and retainer , with crower reginding my oem cams will that be okay?
Brian Crower springs will work for what you are doing.
Make sure to find out from crower if the regrind cams will require that you shim the lifters. And if so find out what size shim.
okay thank you for you help this whole cam situation has been bugging me forever because its pain to get around this.
