Need to replace rear shocks, replace mount at same time?
Just inspect the mount, if it is rusty, replace it. If not than don't. It will be pretty obvious from the top. There is no bearing or anything, just a metal piece with studs. I would of coarse replace the bushings.
Ya, I keep changing. Is it true that the Koni shocks have a couple lower seat options?
When you look at the shock body you will notice there are two locations that will receive the circlip/snap ring. The lower most of which seems to lower the car approximately one inch.
Is that what you mean?
Yes, I read about it some where but I had a shop do the install. I would like my car a bit higher so I wonder if the used the lower snap ring... Do you know if the fronts and rear have multiple locations?
you can machine new snap ring grooves.
Not sure if I want to have them machined. I don't know anyone to perform the process. I wonder if I install the new shocks with the stock springs if it will be lower then stock spring with stock struts? I might just get new shocks for the front too and use factory OEM springs...?
  • Wanted NA 1ga running and driving
    I'm in the market for a N/A 1ga Dsm preferably running and driving that's manual. no preference...
    • Nii
  • For sale 2g 7 bolt engine build parts and mounts,
    New lowered prices on everything!
    • beegeezy
  • For sale 2g 2G Belt Molding Set
    2G Belt Molding Set $170 + shipping & paypal fees** NO peeling or chrome showingYou must be...
  • For sale 2g 2G OEM Knock Sensor
    2G OEM Knock Sensor $85 + shipping & paypal feesYou must be registered to see element.You must...
  • For sale 2g 2G Black Passenger Air Bag
    2G Black Passenger Air Bag $85 + shipping & paypal feesYou must be registered to see...
