Need to finish A/T to M/T swap. HELP!
Yoggy
Dec 8, 2009
Bayamon, Puerto Rico
Greetings, today i just finished my tranny swap using this as my guide:
http://www.dsmtuners.com/forums/articles-drivetrain/231626-2g-fwd-auto-manual-conversion.html
I did everything he said and everything went fine until startup...:ohdamn:
it seems the starter doesnt go in the flywheel as much as it should. it skips a teeth or to sometimes. Its skips after 3 seconds or so. But that should be more than enough time to start the engine. how can i fix the starter problem and what do you think i should do to make it start??? Thanks in advance guys
yup everything was swaped of a m/t gst. i also noted there was no fuel psi when starting it. is this normal??
Not sure if its same for 2g, but when i swapped my 1g, i retained the auto starter but had to add a few shims/washers between the bellhousing and starter. Just be careful not to drop them in the clutch area, LOL
