Need to find switched +12v source under the dash
PaulPDX
884
Oct 11, 2003
LA, California
I need to tap a switched +12v source under the dash to hook up several things like a Valentine 1 and power for gauges... perhaps even an auto-dimming rear view mirror.
Which wire should I tap? I looked at the fuse box under the dash and there isn't even a fuse for ignition there.
I've also been told that there is a thin white wire under the dash that goes to nothing is a switched source, but it is so thin I am not sure if it is good enough to handle more than two powered accessories.
do it right and run it off the heavy gauge ignition wires. use a VOM to check which is the ignition wire(or accessory if you want that instead)
accessory cuts off when the starter is engaged, ignition does not.
  • Wanted 6 bolt NT water pipe
    • chrisman287
