Need tensioner parts numbers
ShawnsGarage
354
Jul 19, 2008
kannapolis, North Carolina
I need the name and part numbers for all the parts that bolt onto the driver side motor mount along with the Tensioner arm. I dont need the arm or tensioner pulley but I need everything else including the dowel for the pivot arm and all bolts/washers.
Just go by name at Extreme PSI or TheDSMGraveyard. NO need for part numbers
The post that the tensioner arm pivots on is part of the engine mount. If it's bad/loose you have to replace the mount and it only comes with the arm, bolt, washer, and idler pulley included from the factory.
