need some feedback
redrockergsx
84
Feb 16, 2010
el mirage, Arizona
Im running a garret 50 trim with 720 injectors and i cant get it to run good at 15 psi at 12psi i can get great runs on it but at 15psi i cant get it to run at 5500 rpm i have it a 15 or 18 % plus correction and i not sure if thats to much fuel cause my air/fuel ration gauged is not pegging out but i know i need a wideband and working on getting one but should i give more or less fuel if you cant help i just have to get a data logger and tune it that way
The narrowband won't tell you anything on how lean or rich you are running. You need a logger and wideband minimum. What are you currently using to adjust your trims?
i using a air fuel ratio gauge apexi safc I buying a data logger but just trying to self tuning it to just get it to run at that psi I can usually get it to run fine by self tuning then tune it in with a data logger but i sold all my dsm stuff when i got rid of my last 90 talon
I running 12 psi and it runs great has lots of power. but when i turn it up to 15 psi just to do it slowly cause with out a data logger i dont wont to try for anything higher just to protect this engine and head this is a good high 11 to low 12 sec GSX. but when i do 15 psi it seems to miss fire or may be fuel cut at 4000 or 4500 rpm at 70% to 80% throttle and i have it at plus 10 to 15 % correction with a safc. I hope this is good info. I waiting till next year to go with a emanage so this what i have for know next buy is a wideband and a data logger
