Need some CNC ideas
Status
Not open for further replies.
Gamble97
2,642
63
Jan 3, 2006
small town, Illinois
I need some practice designing and cutting with the plasma cnc. What are some things you guys would like to see?
Rear bumper defuser like devins talon how he has like 7 evenly spaced holes? That but with stainless or aluminum.
This and have maybe 1/2" frame around the thing
Circles are always a challange to cut
Spark plug wire covers (for regular and COP setups). Especially if you can make them pretty. There is a cad drawing floating around here somwehere, I may have downloaded it. IIRC only a few bolt holes were a little off.
IDK what file type you use, I am sure I can convert it...
Also... I designed some spark plug wire holders if you want to try and cut then out of aluminum.
They were copied/measured from the plastic originals and then redesigned for strength.
I intended to have them cnc cut by a router into plastic stock and not a plasma cutter through sheet metal. I can help you clean them up if you want or if you have questions.
ARGH wont lemme post master cam files... whatever.
Now that I look at the wire cover... Maybe it wasn't designed too well (Don't blame me. I didn't make it)?
cnc the platic 1g radio bezel but for 1g hvac relocation and radio ;P
Can you email me the file [email protected]
I found a spark plug cover, but importing the file things are completely messed up.
Sure, draw me a pic and some measurements.
2g cluster delete (for custom gauhed) and hvac/radio delete for custom gauges.
No problem, draw it out.
If you guys can use google sketchup, it should be easy to export that to a dxf for me.
I am starting small. Metal is expensive for big sheets.
Working on it. I have a few samples drawn up and posted on dsmlink forum.
Am pretty decent with SketchUp, so if anyone needs something modeled, lemme know. Do provide measurements.
Did the dash from photos, but can not upload the .skp file here. Lemme know if anyone wants it, can e-mail.
Aluminum, similar profile but a thicker material that doesn't need the folded edges and a smaller hole for the rad pin. The front edges are bent down, can you machine angles, or use thin enough material to bend?
Here's an underhood pic showing them if you need one.
http://www.assortedpixels.net/transportation/talon/a22.jpg
Hmmm i'm not sure how i can do this without folding something.
Here are some samples of rear diffusers. You guys like any? I'll add all the bolt holes later
Status
