Need some accurate numbers!
Status
Not open for further replies.
deputy865
177
Sep 17, 2007
Fenton, Michigan
Just picked up a 91 GSX.. Less then 3k on both tranny and engine.. I was told that it would be upper 300's for HP.. Was wondering what you all thought for HP.. Car is not tuned just yet.. Im gonna try to get a base tune with the GM Maft.
So what do you think HP is now? After GM Maft tune (if any gains)?
Max boost i should run? I was thinking 22-24psi? set at about 18psi right now..
Figured id ask instead of find out the hard way... :thumb:
Eagle H- Beam Rods
Wiseco 9:1
Clevete Bearings (Mains/Rods)
Cometic MLS Head gasket
ARP Head Studs
BSEK (balance shaft elem. Kit)
Machined crank ( Crankshaft craftsman)
Intake Gasket/Spacer
Poly Motor Mounts
Billet Aluminum Fuel rail
2G Intake Elbow
Tubular Exhaust manifold
PTE 50 trim turbo
PTE 780cc Injectors
OBX Fuel rail
MAF-T W/ 3.5" GM MAF
ACT 2900 W/ 6 Puck Clutch
Extened Clutch Rod
Built Transmission
New OEM Throw out bearing
Walbro 255 LPH Fuel Pump
O2 Housing W/ Dump
Xs Power FMIC W/ Polished Piping
Crushed 1G BOV
Exhaust is dumped at seats.. I HATE IT! So im gonna throw a full 3'' turbo-back on there and get a better BOV.. Found a good deal on a GReddy Type S.. Get it??
Thanks!
Shane
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
