Need serious help my trans is leaking
dahawkster
69
Jan 9, 2011
wailuku, Hawaii
Can somebody please tell me what goes in this hole, is it just a bolt or is it one of those ones with the ball on the end? And if its just the bolt the dimension would be greatly appreciated...thanks
If that's what I think it is the bolt is for the reverse idler shaft and it's 10mmx 46mm with a tapered head to facilitate install. If that shaft isn't lined up anymore it's going to be a bi*** to install without tranny disassembly. Is this a recently rebuilt transmission?
Pull the transmission, take it back apart, realign the reverse idler gear shaft, reinstall the case section, then install the reverse idler shaft bolt/washer, then install the 5th gearset and 5th gear cover.
Shit happens; this is not something you can do "in-car".
