need QUICK advice about the oil cooler ?? can it be removed without harm?
myblack98gst
578
Jun 22, 2003
Elizabethtown, Kentucky
okay tonight on the way home my oil cooler came loose and I ran it over!! OMG I heard it and shut the car off immediatly because I know what it was, so I only lost about 1/2 quart of oil. It ripped the line off right on the banjo fittings
Long story short I drive this everyday to work and cannot let it sit till I can find a replacement part.
My temp ( 2mile) fix was to put large nuts in place of the banjo fittings to block off the flow.
Will this cause a loss of oil flow inside the motor?? I do fully intend to put a cooler back on probably an upgraded one, but I have to drive the car to work tommorow.
16 views and nothing.......
This really is important that I knw in say the next hour
Use your best judgement here. All of the turbo dsm's come with an oil cooler of some sort wether it be air cooled or coolant cooled. If you absolutely have to drive the car I'd just stay out of boost. Oh and fix the oil leak for good.
You'll need to loop it so the oil can get back to the engine, I'd think. I don't know what kind of setup you're running- you're supposed to have an oil/water pancake stack under the filter.
it is basically impossible to loop because it ripped the metal line off the front banjo flush at the fitting.. so I have no way of getting anything on it.
oh well.. I am going tp go see what I can ****** rig for it
    • Sdcryan1
