2G External oil cooler advice needed
An awesome idea I found on here is that the Evo 8/9 ofh will fit on our blocks, as long as it is the 7 bolt block. This way you can run an external oil cooler and relocate your oil filter (from sideways to down).
The cooler will be similar to a side mount intercooler, but that's if you want to remove the sandwich cooler.
