Need opinions on this setup.
PFC_CiarlilloM
234
May 22, 2011
Euclid, Ohio
I was looking to do a full exhaust replacement on my 95 Talon N/T. Its basically budget *thanks college student life... sigh*
Anyways heres what im thinking.
Header/downpipe
m2 Header Down Pipe 95-99 NT Eclipse Talon ES RS GS | eBay
Cat
2.5" Magnaflow Catalytic Hi Flow Cat Converter 94106 | eBay
Catback
95-99 MIT ECLIPSE TALON NON-TURBO CATBACK EXHAUST GS RS | eBay
Need your guys' opinons and if im missing anything let me know.
Thanks!
Personally I would say no to that Cat-Back. Without a resinator you are asking for a raspy sound. I can't find the system I bought, but it was 3" mandrel stainless steel, with two resinators (1 lg,1 sml). It sounds wonderful, and not a single hint of rasp.
If you don't have emmissions you could ditch the catalytic converter and put a resinator there instead. In my experience the longer the resinator, the less rasp you get. Which will probably be something you will get because you are replacing the header.
Yes, get a resonator. If not, you sound like a bumble bee, unless that's what your after then knock yourself out.
I have a ''top speed" on mine, its not bad. Really mellow sound, even strong enough to rip a speed bump out of the ground and the can not fall off :)
Okay so heres what I came up with
Option 1
Header
m2 Header 95-99 NT Eclipse Talon ESI RS GS Base 2.0L | eBay
Catback
95-99 MIT ECLIPSE 420A NT NON-TURBO N1 CATBACK EXHAUST | eBay
Cat
Option 2
Header (Same as above)
Catback
Resonator
OBX 2.5 Universal Oval Muffler,Resonator Type,KV2013 | eBay
Thanks
