Need oil pump help on 4g64
nonkjo
Jan 4, 2023
Dallas, Texas
Hello everyone. James here. I'm in north TX and I'm swapping a 4G64 from a 1999 Montero Sport into my 1987 Raider/Montero.
This project has been going on for a while now (almost 2 years...I'm married so not much more explanation needed!).
The original disassembly of the engine happened Summer 2021 and when I pulled the oil pump, as is practice, I kept all of the bolts in the proper pattern in a cardboard template. Fast forward to this past weekend and I can't find my oil pump bolts or template anywhere. I had to get new oil pump bolt but I don't remember which hole each bolt goes into since they are different lengths.
I've searched the forums and found this question asked before but the best I can find is for a 6 bolt engine here: https://www.dsmtuners.com/threads/oil-pump-bolt-sizes.434924/
Does anyone have a similar image for 2G 4g64 oil pump or is the image from the earlier engine close enough to get my in the right holes.
I truly appreciate help with this. It's pretty embarrasing.
The long bolts go at bottom left most others are short bolts if u need some pullapart has helped me but always buy new oilpumps ebay is cheapest then rock-auto is a must I may have a few bolts let me know what size u need I've got a 2001 kia optima 2.4l they put these in a bunch of brands
  • For sale Evo 8 steering wheel with dsm adapter welded on.
    Evo 8 wheel with welded adapter for dsm
    • 98TalonPandaTSI
