Need o-ring for fuel sender
2GeeEssEcks
Oct 29, 2013
Marana, Arizona
Been looking high and low for a part number or a solution to my problem, none found. I'm after the rubber o-ring off a 2g fuel pressure sender, better shown in this picture:
It is the O-ring that seals the white plug to the hangar. I'm getting a crazy leak from that area. If anyone has the part number or could push me in the right direction that would be great.
Ok. Do you have a home depot or lowes? Any hardware store? Im sure you can find the right size o ring. Just have to check a few places.
Mine cracked badly when i removed it to run wiring to the pump(rewire). I ended up using JB weld and completely eliminating the plastic piece. Not the prettiest thing but it worked.
