bjbaxter
- 115
- 0
- Mar 19, 2006
parkesburg,
Pennsylvania
Wats goin on guys?!?
OK, this is the problem that I am having and I'm looking for any information or guidance to it. My 98 Gst just shut off while I was driving it one day down the road.
I wasn't beating it or anything while I was driving it either. So I had it towed home and hooked it up to an OBDII scanner and came up with a crankshaft sensor fault. So I got that out and it was actually broke into 2 pieces so i thought that was my only problem. Well I got everything back together and went for my first startup since it ran last time and it wouldnt start. I am getting no spark or anything so im thinking it may be the fuel pump relay. When i turned the key on to "acc" all i got was a click(no whine after it like there should be). The car would turn over and all but just wouldnt start up. I am having the hardest time trying to figure out ### the hell is goin on
If the fuel pump relay is bad, would it cause the problems that i am having?? If anyone can give me some help here, it would be the greatest relief I've had in a long ass time. Thanks alot guys!!
