need help with wire ident
3kgt2nv
2,023
19
Jan 7, 2011
poughkeepsie, New York
was looking into my running issue and found a wire near the ptu that ends with a round plug on it.
what does this plug go
it comes out of the harness right next to the ptu wire. the wire colors is black with a white stripe
the connector has a gray inner part
ok thats been deleted.
here are the codes i pulled
21 coolent temp sensor
22 crank angle
23 tdc sensor
31 knock sensor
41 injector circuit
whats weird is the car will start and run but stalls out. could it be a loose conection somewhere or are all my sensors bad?
its a 90 with a different head on it
Could be check wiring, sensors could be bad its a old car, things happen. 31 wont matter, its just for knock everything else i would check out.
