help with idenifing wire
skatershawn
1,271
13
Feb 27, 2009
Austin, Texas
Im trying to install my boost gauge in, and in a thread it says to put my yellow wire for constant power and splice it into with a "WHITE" wire in the ignition?!?! i took my column apart and exposed the wires to the ignition and all i saw was six or so wires and the are all black with colored strips.... one DOES have a white strip... IS THAT the wire i tap into??
Thanks
shawn huetter
ACCESSORY/HEATER BLOWER Wire is:---------BLUE/BLACK (+) (BLUE with a black stripe)
IGNITION Wire is: --------BLACK/WHITE (+) (BLACK with a WHITE stripe)
These wires will be fat 10 or 12 Gauge wires
My wiring diagram says it is just a Blue wire. It will be powered when in ACC and Run.
ok i so didnt really notice he told me it was blue w/black stripe.... BUT there is not such wire on my ignition... there is there is a solid blue... and a solid black... guessing the solid black will be the ground!!
goes like this
[1][2][3]
[4][5][6]
1)Blue
2)Blue/red stripe
3)black/red stripe
4)Black
5)Black/yellow stripe
6)Black/white stripe
ooook... figured it out!
i DIDNT have a volt meter BUT i made one with two wires and a bulb!! ;)
Call me ghetto, i dont care!!
hooked up boost gauge but havent mounted cause i dont have a gauge bezel!!
