Need help with mmcd 1.7
nkosi
320
3
May 17, 2004
montreal, QC, Canada
Hey guys can u help me with the meaning of some of the new abbreviations on the mmcd 1.7 there's a few new additions i have been searching to see if i could find out what they mean ...here is a example ;
ANA1
ANA2
VSS i got this one the speed sensor
GREV
LBMN i think this one is LBS/MIN airflow
FLG0
FLG1
FLG2
the car is 1g talon 92 with palm m105 ...any links or help will be appreciated ...thanks guys..:D:D:thumb::talon:
I have a bit newer MMCD 1.8g on mine if you Goto Options > Sensors > then click the little i in the top right corner of the list that pops up it will tell you what they all are
I've got 1.71 on my computer So I loaded it on my Palm Emulator and cam back with this
ANA1 - Sm Analog input # 1
ANA2 - Sm Analog input # 2
VSS - Vehical Speed
GREV - Airflow Expressd per revolution
LBMN - Airflow Expressed in Lb/min
these are dif. flags for dif.relays and sensors
FLG0 - (F) Fuel Pump relay, (A) AC Clutch
FLG1 - (P) Canister Purge,(c) CE light
FLG2 -(T) TDC,(P)P/S switch (A) Ac switch,(N)Neutral(A/T),(I)Idle Switch
VSS - Vehical Speed
Thanks alot man thats how i figured then out the first time but i couldnt for the life of me remember where i saw the tips... i have a question for u where would i get mmcd 1.8 is there a link u could hook me up with to find it and the palm imulator also and does the paml imulator help u transfer info from the palm handheld to your computer...and what are the differences from 1.7 to 1.8 ..thanks homie again for reminding me . :D:D:thumb::thumb::talon:
I'll send you a PM when I get back here in a bit... headed out the door right now
