2G Need help with cam angle sensor
Did you get an OEM sensor? Cause if you got it at some place like autozone, it may be the sensor. Autozone sells mostly cheap crap. Duralast sensor can be bad out of the box. If I had to guess, id say they have atleast a 5% fail rate on new sensors.
Na it's from O'Reillys
Is this a black top/green top cas, or is it a 2G cas?
It's a 2g cas
There is an oring on the cas and an internal seal to the cas. Not sure the internal seal is replaceable.
Yeah I knew about the O ring but I wasn't sure about the other.
I didn't think there was suppose to be any in it. I read on dsmtalk that there was suppose to be a little oil in it. I'll see if I can't stop the oil from getting in it. Have you checked yours recently to see?
You can remove the lid and if there is oil inside you found your problem.
I'll try it thanks
You can also use a small screwdriver to compress the contacts in the plug cause they get loose from being taken apart and put back together
It's weird but it only does it after I unhook my battery and it does it every time. It will work after I crank the motor over a few times shut it off and repeat several times and it will finally work.
I tried that but it doesn't make any difference
