Need help soon. Bcs
91talonawdtsi
53
Dec 1, 2005
kansas city, Missouri
Ok so i was sick and tired of my crappy ebay boost controller and took it off. I ran a hose from my wastegate actuator and one to the turbo then connected them to a t. i ran the t to the bottom of the bcs and ran a hose from the top of the bcs to the intake. Well the problem is i started the car and now when i give it gas it chugs and is building boost while in neutral?
is there any way i can disconnect the signal hose to the actuator and plug off the other hose and just run wastegate pressure? i threw a cel too but dont have a reader anyone know if my evo scan does diagnostics?
thats what i just did. what was wrong with it do you think? it was stuttering and building boost while sitting still? I could probably figure it out i just cant think right now ive been working outside since six and i think the heat may have made me retarded. but thanks that worked.
ya i did one the only thing is that it worked fine till i hooked up the bcs now that im running straight from the wastegate to the turbo its fine? i would really just like to be able to just set my boost to 16 and not have to worry about spike or drop!:cry:
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
