need help oil squirters!!!!
rowdygst
230
Jan 12, 2011
san antonio, Texas
ok, in the process of building my block, by accident i broke 2 oil squirters, my block has wiseco pistons/eagle rods.. i read threads saying oil squirters are not needed with forge pistons, but they are needed with cast pistons aka stock. so my question is this. do i need to run them on my built 6 bolt or should i block them?
if i need them, where is a place where i can find 1g 6bolt oil jets or oil squirters whatever they are called
dang 140, i tought someone had said they were like 8 bucks a piece LOL...fml, i guess ill have to wait another 2 weeks to get this cause i already spend all my check on some other crap for this stoopid dsm
The squirters themselves can be had for ~$11 a piece (check ExtremePSI.com or JNZTuning.com with part number MD329806). A large part of the cost in the Mach V set linked above is the banjo bolts which, along with two crush washers per bolt, are around $22 a piece. If you already have the banjo bolts, look into getting new crush washers ($0.18 a piece at JNZTuning) with the new squirters and you greatly reduce the cost.
