Need help identifying my talon
Jon W
5
Sep 30, 2019
Melbourne, Florida
So I recently purchased what was supposed to be a 98 however I have been told several things are not right about my car and I am trying to figure out what happened. The door sticker says manufactured Oct 2017. The title reads a 98 eagle talon. Vins on dash plate and door sticker match the title. Also car fax lists vin as 98. However it has come to my attention that the car should have side door moldings and shouldn’t have a black dash. And has the wrong side skirts. Any help or information is appreciated thanks.
What's on the title and the VIN matching it are what matters, so I would go by that. The doors could've been replaced or had the moldings shaved. Black dashes and side skirts are commonly swapped out. The date of manufacture is just that, the date it was built. New model years come out before the beginning of that year i.e a 98 model year car would be in production and start hitting dealers before the end of 97. My 97 talon was built in October of 1996.
Swapping a VIN to another chassis is doable, but I wouldn't suspect that's the case with your car just going by the color of the dash and the trim discrepancies. If you give the VIN to the guy that does the 2gb talon registry he'll be able to tell you everything about it.
Here is my door sticker
Thanks for the help so far. Just searched for the registry guy and found my car in his list. By that dash is correct color so just looks like some exterior mods.
Not all 2g came with black dash, generally only 99' for Eclipse and I'm not sure on the Talon, but I can assure you that not all of them were made in black, some were grey and some tan and even some blue.
  • Wanted 6 bolt NT water pipe
    • chrisman287
