shadowdrag
- 191
- 1
- Oct 17, 2005
Beaverton,
Oregon
I just checked oil level, and the oil was almost completely gone, just a little at the tip of the dipstick. Did an oil change and found oil leaking all over tranny, coming down from back of the engine onto the left drive axel and cat converter. There was no sign of oil leaking onto the concrete because it runs down onto the down pipe and gets burned. I lower the boost to 14psi and the car still runs good. no sign of oil in the coolant or coolant in the oil. Yesterday, I got on it on first gear abit to hard and oil came pouring out. You can see the smoke from oil burning coming out from under the car (side fenders). Stock boost gauge knock sum ran up to 7 counts of knock and was stuck there.
What can this be? Did I just blew my HG. If so how much is it to get it done?
